Radiator and valve hookup problems
Casinojunkie
Member Posts: 36
Today I had to remove a radiator to lay new carpet.
In doing so the nut which connects the radiator to the shutoff valve split into two pieces.
Now I have also noticed the shutoff valve opening is oblong.
I know I will have to replace the valve.
I also noticed the nipple going into the radiator is oblong in shape. My question is, "Is the nipple going into the radiator removable, and if so how do I remove it, or just what do I have to do to make this radiator usable again?" Oh by the way it is a steam one pipe system. 1 1/2" pipe. Thank you for your help. Dallas
oblong valves
Sure it's removeable. When you buy a new valve, it will come with a new spud and nut ( the piece that goes into the radiator). Now that the nut is off, you should be able to turn it out of the radiator (counter-clockwise). Get a big wrench!!! IF it won't budge, you will have to cut it out.If you don't know how to do that, get a pro to help. You can make things worse by ruining the thread in the radiator.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 392 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 46 Industry Classes
- 49 Job Opportunities
