Buderus G115 28 Cold Start
RoosterBoy
Member Posts: 459
hay guys last week when my installer was installing new duct work in my house we had no heat in the house I had to heat with wood for a few days wile duct work was being installed.
I have a g115 with 2109 controller and lt 160 hot water tank we put the 2109 on summer mode because there would be no call for heat
since we don't use allot of water the boiler only ran once a day and the temp of the boiler went down way below the 100deg I was wondering. in the summer is this ok for the boiler to start off cold everyday? or should the boiler stay at a set temp. my tech thought this was odd because most boilers he works ok stays a set temperature
im just worried that cold start will shorten the life of the boiler is there anything I should do or is this normal
thanks
thanks
don't sweat it...
you will be fine.
WHat Kevin said...
This ain't your grandpas boiler any more. It's made with a different type of cast iron that is resistant to the corrosive tendencies of cold starts. It'll be just fine.
ME0 -
Rooster Boy
Quit your cackling:)...............It'll be alright.
Enjoy,
cheese0 -
Always learning
And always confused!
I thought you should never cold-start any oil fired boiler to avoid condensing inside the boiler, and prevent all those nasty stalagmites, (or is is stalactites, I always forget), from forming the rock-hard blockages that I've seen on boilers with pinned sections.
Is Buderus immune to these problems? If so, is it the triple-bypass design, or the cast iron itself?
Can you tell I'm not an oil guy? :-)0 -
The main key to cold start is not the temperature that the boiler starts at but rather the temperature that it ends up at by the end of each firing. The Buderus should get up to a minimum of 130 degrees if I remember correctly.
Ron0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
