Wiring Controls
Mike Kraft_2
Member Posts: 398
Wiring controls and neatness..........I tip my hat to those of you who make it eye candy.I struggle for neatness and the time it takes makes me wonder.
Doing my own wiring though,is a learning tool for understanding the completeness of a system.With all of this said....I will forge onward and wire my stuff.
But don't you HATE when the screw goes "TINK" and the cellar floor seems to swallow them??? :)
cheese
cheese
tink
Mike---I carry a nice clean white drop cloth, which I spread out when having to do any fine work with small parts in dark basements. Just a little trick I learned from repairing pinball machines. Best Wishes J.Lockard0 -
Wire
Them 1900 boxes screws !!!!! Them little buggers squrry right under the boiler the first chance they get.
Thermostat wire .......I haven't found a perfect skinner to remove the outher casing with out the inner....
Zone valve neatness....... With out using green field it's a matter of taste...... I'am a curlie cue type
Buderus.....I use the under the jacket to the max....0 -
Best Dollar I ever spent
was on this $1.00 hemostat. Dealing with alot of low-voltage control wiring in small tekmar and wirsbo terminals, I let this thing do the work with one hand, and handy little flat tip screwdriver does the rest.
As a wholesaler, I love getting out of the office to go troubleshoot control wiring. It really makes you think the process about how the whole SYSTEM will operate.
Wish I were closer to some of you so that I could get out even more.
Regards,
PR0 -
OH YEAH
The GREAT PICKER UP TOOL !!!!!!!!!!0 -
Hmmmmm.
What are you guy's smoking ?~
Hey Jim!
Thats how I got my nickname! damn I wish I had thought of that back then!I lost quite a few of those cpu board screws and coil bracket screws!
Al0 -
pinball
Is an on going addiction, currently own or have ashared interest in over 100 machines plus a few videos, bowlers and my favorite Skeeball. Best Wishes J.lockard0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
