Air t'stats
John Fernandez_2
Member Posts: 40
I have been called out to repair a heating problem at a local school.......big closed loop system, problem is in the thermostats, they are the air actuated type and control pneumatic valves at the radiators. The problem is in the air compressor....what PSI do these t'stats work at under normal operating conditions?
it depends on the stat usually the main air compressor runs about 100 psi then you go into a filter/drier then regulator most are regulators are set low -15 psi the thermostats can be tricky and different types and brands run differently depending on the valve etc...0 -
lotta times water is the fly in the ointment.
see if you can get a blast of water out of the compressor... what are the magnahelix gauges reading? do you have the tools to be doing this?0 -
Normaly....
15 PSI, reduced after the air compressor. In many schools they have a night set back using 20 PSI switched by a time clock. The valves will be working at 3 - 8 PSI for heating. The less air pressure the more the valves open.
As stated above, water in the lines screw the works up. The compressor should always have an air dryer and auto blow downs. Oil from the compressor is also a major problem.
tom0 -
Weezbo was right
Lots of flies in the ointment! I got the system dialed in...........works like a charm. Thanks for the input fellas!0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
