Boiler response time
Paul_28
Member Posts: 113
I have the Buderus G124X/25 installed with the R2107 controller. This mourning the outside temperature was 18* the boiler water temperature was 153*. It took 5 hours for my home to warm up to 70*. The night setting is 65*@10:00PM and the day setting is 70*@5:30AM. The settings on the boiler are 67* Night and 72* Day.
My home is well insulated with good windows and doors. How can I improve the response time?
boiler response time
Talk to Joe at Buderus and about the correct settings for your specific application.
There are many adjustments that can be made to improve response time, but they all depend on getting the unit set up correctly to begin with.
Building response, type of heating (panel, baseboard, radiant), proper reference temperature, correct mode of setback all need to be checked first.
Once these are all verified to be correct, they can then help you adjust your heating curves for optimal performance using things like offsets, or perhaps tweaks to the reference temperature.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
