PDF problems with 'The Library'
John Shea
Member Posts: 247
Does anyone have problems opening some of "The Library" Acrobat files?
An example of one I'm having problems with:
http://www.heatinghelp.com/pdfs/26.pdf
I did some poking around on the net for the error I'm getting (There was a problem reading this document (9)) but all I can find is that you need a newer version (3.0 or higher) of Adobe Acrobat.
However, my version is 4.05
Thank you
Thank you
Cut and patched
your http and it opened fine, John. It was 6.0.0 -
I was having problems some time back
but the suggestion was made to 'right-click' and "save target as" to save PDF files then view them. It seemed to work for me.
Regards,
PR0 -
Got it!
Turns out I was viewing with Acrobat 4.05 (not Acrobat Reader) Downloaded reader 6.0 and all's well.
Thanks guys.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
