Determing when steam valves are shot
Chris Bain
Member Posts: 28
How do you tell if a steam vent is clogged? Can you actually blow through it with your mouth? I have a Hoffman 4A main vent and I can actually blow through it from either end. Is this the real test, and does it work with either main vents or radiator vents (I have a mixture of Hoffmans, Gortons, and Durst).
Thanks.
Thanks.
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
