viesmann
shawn_5
shawn_5 Member Posts: 52
I have a homeowner call today and said that she had to go hit the reset button on here viesmann gas boiler.It has outdoor reset etc.any thoughts not familar with viesmann products.
  • marc
    marc Member Posts: 203
    read the fault code on the comfortrol
    control on the boiler. then look up code in i/o manual. could be at least 6-12 or more reasons for the boiler to lock out. they are a very smart control they will tell you what is wrong before you go to the job.. marc
  • Weezbo
    Weezbo Member Posts: 6,231
    thats a large question with so little information....
    it could be a bunch of things...it may be something simple like outdoor weather conditions,High wind gusts,maybe small vaccume leak in room bought about by starting a fire in a fire place or the opening and closing of a door that is in a tight home ....my crystal ball draws a blank...
  • mac
    mac Member Posts: 16
    Do you know which model? Atmospheric or Vitola with gas power burner?
    Good resource: Viessmann Tech Support: (800) 288-0667
