radiator repair
matt_20
Member Posts: 1
Being new to the old hot water heat systems this FYI may make some of you say DAH! When I decided to take some of my cast radiators apart for repair I found that wedges made out of oak worked in prying apart the sections. But what worked GREAT was a plastic wedge I use in cutting wood. I swear I hit the thing with a framing hammer no more that 6-7 times and the sections were free to pry apart. Maybe I was lucky but it sure worked!
Radiator repair parts
Where do you find radiator repair parts?
I removed an old cast iron radiator to install carpeting and broke the fitting that connects the radiator to the shut-off valve. I was able to get the broken part out of the radiator, but don't know where to find a replacement.
Any help is appreciated.0 -
rad repair
you ned to replace the valve and the spud that broke there is a differance between the shut offs made for steam and hot water0 -
Radiator valves (both steam and hot water) are still made and geometry hasn't changed. Any plumbing house should be able to order--some big ones where that sort of heat is still common should stock. As mentioned, make sure you specifiy steam or hot water when ordering.0
- 120 Geothermal
- 394 Solar
