Power venters for older boilers
Ted_9
Member Posts: 1,718
I have a customer looking to power vent 2 older gas fired W/M boiler approximatly 30 years old. Which brand or model would cover that. I dont have model numbers yet.
PATRIOT HEATING & COOLING, INC.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=343&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hay Ted I know your an expert ive seen some of your beautiful work but im sure a fields control swg stainless model would http://www.fieldcontrols.com/swg.html
that's what I use on my new buderus
here is the sizing chart so you can check if your input ratings so you can size it for what you need
http://www.fieldcontrols.com/swg.chart.html
oh also Ted I have used another swg that was not stainless for 5 years with no problems at all when you do service for there boilers every year just make sure you use the swg supper lube oil the motor will last lot longer I just wanted the stainless because it looks nicer and I was getting a new system installed and did not want to use old stuff no rust on the stainless still looks bran new
hope that works for you
thanks Roosterboy. Thats what I was looking for, a chart with models and sizes.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
