setting pressuretrol
Sam Rosenfeld
Member Posts: 1
I have a Honeywell Pressuretrol whose settings may have been changed by someone who didn't know what he was doing. I have all the data on my fairly new Weil-Mclain boiler and old pipe system including the data on the pressuretrol), but it doesn't say how to choose or calculate the settings for the differential and the pressure at which it will close down.
I'd appreciate any advice or reference.
Thanks.
Sam
Thanks.
Sam
Sam, I am not an expert but have learned a bit from these intelligent and helpful folks on here. I assume it is steam heat. The PSI for the steam should be set at .5 - 1 psi. From what I gather, anything more than 1 psi is bad, be afraid. Hope this helps.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
