Corroded LWCO
Bill Campbell
Member Posts: 3
We replaced an older oil fired boiler w/ WM GV-3 onto a copper baseboard system. The main in the basement is black pipe, mono-flo set up. We installed a hydrolevel 1100 LWCO in the return riser. Two weeks after install, there was water dripping from the electronics of the LWCO. After removal, the probe had a lot of "crud" build up, which I rubbed off. The probe is pitted with many tiny holes. Electrolysis at it's finest. Why? What's happening in this system? What should we be looking at?
Could it be stray voltage?
Is the piping system in the home being used as a ground somewhere upstream from the LWCO? Stray currents don't have to be strong to do a real number on components. I'd try two things:
1) Look "downstream" for grounds and attach them to the incoming copper water pipe, or better yet, to a dedicated ground rod outside.
2) Electrically jumper the replacement LWCO. If the LWCO still fails in the future, you can discount the stray current theory. A bare ground wire attached to the pipe above and below the LWCO should do the trick.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
