Raidator help
Big Ed
Member Posts: 1,117
This happens every time a home owner hires a carpenter to do heating work...
Check the vent see if it's open or if you even have one.
Burnham makes cast iron Baseboard that you can use for steam...
need help with radiator
I am having a problem with heating in my home. I have steam heating, when the contractors we remodling our floor in house they removed the old cast iron radiator and put in a baseboard radiator in the bedroom. Needless to say that it take about an hour and a half for the radiator to get warm. I was hoping that i could get some advise in regards to a solution. I cannot install the old radiator back because old one was picked up by someone. Also we are interested in getting something that is not so bulky. Is there any baseboard types of radiators that work well with steam?
Thank you0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
