Best Thermostat for Steam Heat
Steve Johnson
Member Posts: 1
What is the best type of thermostat for steam heat.
Best Thermostat - Steam
For simplicity and reliability, I prefer the Honeywell Round, with adjustable anticipation.0 -
You can up date it with...
the new FocusPro, set it for 1 cycle/hour, choose from either the large screen or standard screen. Non programmable, mercury-free, +-1 degree accurate. Battery-powered for wide compatibility. 2-4 button operation. Available from any Honeywell distributor or heating pro.0 -
thermostats
Dear Bill - What about the "the round" type but ditgital? It doesn't need batteries, Hg free, etc. It looks like you use dip switches to set the cycles. Any thoughts? Thanks!All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
Steam thermostat
I have used a White Rodgers computer type thermostat on my home that has a wide differential range adjustment. As it comes from the factory it has a very short cycle, as for forced air. But it can be set for a very long cycle, if you wish.
T. Robinson, NY City.0 -
The T8775 Electronic Round would be my second choice...
with steam, since some steam systems shut down power entirely during the Off cycle, and the T8775 is a power-stealing unit. If there is voltage it will work; pricewise, it's a bit more expensive than the FocusPro. The FocusPro uses regular AAA batteries, and they last at least a year, and give about a 6 week visual warning before depleting.0 -
I agree ...
The honeywell ROUND works best. I tried the dig's...and the Focus Pro. Worked TERRIBLY on my system...Sorry Bill!! But the old-fashioned Round works like a CHARM!! Especially on the millivolt I have!0 -
What about the Visions 7500 Programable
Set for Steam system 1cph??0 -
can someone explain the 1 cycle per hour?
i have a honewell box type thermostat with the coil inside that you can make it kick off the heat before it gets to the set temp so it gives time for the heat to radiate.
do i have to be concerned about this 1 cycle per hour? is it already built in? is there some way i can check? i have a 1 pipe steam system........
th0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
