Cold Skimming
Matt_27
Member Posts: 7
I have an old Weil-McClein Steam Boiler (from 1940) that has two small valves above the water line. They have unusually shaped outlets about about 1/2 inch in length with a flared end. My question is ....Does anyone know what these could be? Could they be used for cold skimming? I have oil in my boiler water and I wonder if I could use one of these spigots to skim the oil off the water?
Is the valve outlet on the flared end about 1/8" dia?
They sound like gauge cocks, used to determine the water level in a boiler when the gauge glass is out of service.0 -
Yes, the ends are about an 1/8 at the opening. How
do they work? Sounds like they wouldn't work to
skim the oil off the top.
Jeff0 -
Gauge Cocks
If they are the same age as the boiler they probably won't work!
They work best when under slight boiler pressure so be carefull:
Open the top one---Steam or water comming out? Steam? O.K.
Water? water level probably too high. Close valve.
Now carefully open the lower one---Steam or water comming out? Steam? water level possibly too low. Water? water level O.K. Close valve.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
