steam thermostat
Vicky
Member Posts: 6
I have a number of problems that I am chasing down in my 1900 steam heated house: wet steam, short cycling, a little bit of hammer. I do have the required 28" from water line to lowest steam carrying pipe (the wet return) but the boiler piping is a bit odd. Before I resort to drastic measures (such as repiping) I've discovered that the thermostat I have, a Honeywell MagicStat/32, does not have "a setting for steam/gravity air" and that [c]ycles would not be long enough for accurate temperature control." It seems like this is a good place to start. Can anyone recommend a programmable thermostat for steam?
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
