Olsen Quantum 90
Roy_4
Member Posts: 17
I just installed another Olsen high efficiency Quantum 90 condensing boiler. The customer wants a programmable thermostat installed along with it. Would anyone have any experience with set-back 'stats on a h/w heating system??? OR why I should'nt do this???? I'm North of the Border....the Olsen has a cast aluminum heat exchanger, sealed combustion. Fairly new in the marketplace, I believe. Anyone with experience or thoughts on these????
Thanks,
Roy
Ontario, Canada
Thanks,
Roy
Ontario, Canada
Olsen
Roy.
I work the technical assistance line for ECR International - Olsen Division.
Please call me if you have questions at 519-627-0791 ext 228.
I would be happy to assist you.
Mike0 -
I too have a
question on an Olsen 90
Please contact me directly at tsp77@shaw.ca
Thanks0 -
Olsen Quantum 90
Mike,
Thanks for the reply. I'II be in touch with you during regular business hours.
Roy0 -
Q 90
the hot surface ignighter is unique on this system make sure someone has them in stock or you might get stuck , lennox is useint them for the replacement for the complete heat system0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
