Size to heatloss or existing radiation ?
You do a heatloss for a job and get 60,000 btuh. You determine the existing radiation can deliver 80,000 btuh.
Do you buy an 80,000 or 60,000 boiler and why ?
Steam or hot water?
Steam · 80 output, you need to match the rads.
Hot Water · 60 output, you run at cooler temps and save $$$.0 -
Why do you match the radiation on steam as opposed to hot water where you match the heatloss ?0 -
this is for a hot water job by the way.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
