Pulling radiators to replace flooring
jtstone360392
Member Posts: 2
First, I am a complete neophyte in this area. I was searching the internet on pulling radiators and found this site. I am replacing flooring in a bathroom and kitchen in a 120 y/o home. I would guess that the floors have not been replaced in 35-40 years. What are the dangers (?) of pulling these radiators and then replacing them after the new flooring is in? What questions should I ask the plumber? What is the best way to drain the system so that they can be pulled but keep the house warm enough to put the flooring down? Thank you!
pulling rads
Janet, it depends on what kind of system you have. It can be difficult to keep the heat on if it's a hot water system and you need to remove only a few rads at a time. Jumpers may have to be put in to keep the flow moving. If it's steam, usually you can pull a rad and cap off the piping and keep the system up and running. DEFINITELY consult a pro on this one.
Hot water system w/expansion tank
Hi Al,
Thank you so much for your reply. It is a hot water system and I have an expansion tank. I've never drained the entire system before, but definitely plan on using a plumber. The two radiators in question are both on the first floor (kitchen and powder room/laundry area). What kind of expense should I expect and are there any questions I should ask to make sure I get a plumber who really knows how to do this. I use certified plumbers. Is there any danger in damaging any part of the radiators/system in the process? Thank you.0 -
Careful
when you remove and re-install. One recent post had a general contractor replace a floor. When he went to re-install the radiator, it was now too high to re-connect as the tile floor created a height difference between the piping and the rad. Otherwise it should not be a big deal to remove and reinstall with this in mind. You should not have to explain this if you use someone who knows what to expect. Good luck!!0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
