Zone valve and thermostat question
my old buddy Crispy Chicken with a wiring problem . One Honeywell zone valve , when powered up , would not open . In fact , it stayed closed harder than the normal spring action . When the power was shut off it would open manually with the spring , like normal . Turned out to be a defective cheapo Rite-Temp thermostat , letting power run through it even with the switch in the off position . Took the thermostat off and jumped the wires and the zone valve worked fine .
Anyone ever have that happen ? Have a zone valve stay closed harder because of a defective thermostat ? We both thought it was the zone valve just being stuck , but changing the head and having the same problem proved us wrong .
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
