Radiant Software
Brian_19
Brian_19 Member Posts: 115
What is your favorite and most practical design software for radiant heat. I have been using Wirsbo Radiant Express 4.7, and today I tried Advanced Design Suite 6. After computing the same rooms in each program the results were not even close. One had the load at 18,000 btu's and the other had it at 8500 btu. Which one is right? What program do I trust?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=336&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • S Davis
    S Davis Member Posts: 491
    Wirsbo
    Just curious wich program had the higher number?
    S Davis
    Apex Radiant Heating
  • Brian_19
    High Number
    The older Radiant express had the higher numbers. Quite a bit higher.
  • Ted_9
    Ted_9 Member Posts: 1,718
    Its probably some kind of sttings differance or just some item was differant.
    PATRIOT HEATING & COOLING, INC.
  • Constantin
    Constantin Member Posts: 3,796
    Assuming both are based on Manual-J..
    ... their numbers should be quite similar. I would be surprised if one program could justify a 2x difference, assuming that infiltration, design day conditions, wall thicknesses, window dimensions, etc. are similar.
    For example, even though I used HVAC-Calc and my contractor used Wrightsoft, the sums came to within 10% of each other. Such subtle differences are easily explained by different wall material choices, etc. Incidentally, my contractor calc was 10% lower in its estimate.
    So, I'd review infiltration and window sizes. Windows are wonderful heat-sinks and if you accidentally added a one here or there, then the whole calc goes haywire. As my boss at ADL would say, "the problem with a model is that it always gives you an answer", which is another way of rephrasing the old GI=GO adage WRT computer calculations.
  • Jed_2
    Jed_2 Member Posts: 781
    Software
    I'm not familiar with Wirsbo's program; I use an earlier version of Warm Source, and a current version of Ipex Radiant, and an earlier version of Wright Soft Right Radiant(Zurn). More recent, sophisticated programs have far more default selections and detailed value settings. i suspect this is the case with ADS 6. Read the instructions more carefully. They can be subtle, with large consequences.
    Jed
  • jp_2
    jp_2 Member Posts: 1,935
    pencil & paper
    learn how to do it long hand, learn what R & U factors actually mean. then when something like this happens you know whats up. relying on black box software is dangerous to your occupation!
  • Jed_2
    GI, GO
    As with computer software, pencils have erasers. It's all in the key strokes. But, computers don't make arithmetic errosr (whoops) errors.
  • Rookie
    Rookie Member Posts: 175
    Watt Radiant
    I currently use Watts Radiant nice software easy to use.
  • jp_2
    thats true
    if you don't understand the data you put in, you're sure the heck not going to understand what comes out! computers should be used as tools not as a crutch. understand heatloss, not just how to stroke the keys.
  • S Davis
    Wirsbo
    I use 6.0 allmost daily and have had no problems, I had 4.8R4 before that and noticed very little difference in the heatloss calculations when importing 4.8 jobs into 6.0 but I did have to go through all the parameters and make sure they were the same.
    S Davis
  • Jed_2
    that's true
    touche'
