Low Celling
David Sutton_5
Member Posts: 87
Hi Guys, i have a custemer with a crawl space and from the slab to celling is only 48" high and the thimble in the chimney is only 3" from the joist, whats a good cast iron boiler that will give me the head room and have a frount clean out....Thanks David Sutton
oops i forgot to mention that its oil heat :)
Been there done that, have the shirt to prove it..:) The Burnham LE sound's like an option in your case. I believe it stand's about 30" to the top of the flu collar. The unit is top vent..Just make sure if you go this route to follow the direction's with the unit.
http://www.burnham.com/residential/ledim.cfm0 -
3 pass horizontal flue
models would give you more room for flue piping and putting a barametric draft regulator in. Crown freeport, Buderus G115, Biasi, NY Thermal's Oddesey would all fit.0 -
Both
the Peerless WBV and Weil Mclain Gold have optional rear outlets for the fluepipe . Floor to top of the WBV is 35 inches , the Gold a bit shorter . The special Weil 3L has a supply port in the front of the boiler , as well as on top . Both have options for a coil too . Don't forget to take some pics of this one .0 -
Hello Ronjr
how gos the battle, the thing with the w+m is top clean out as with the perless, i don't think you can get a tankcoil in th le from burnham , can you?...David0 -
low clearance boilers
Energy Kinetics System 2000 stands 26.6" high, with a front swing down door. They also have a low how water tank, measuring 22" high and 32" wide. See them at www.energykinetics.com0 -
Top cleanout should be no problem
Our servicemen have about the same clearance on these hanging boilers as you will have in that crawlspace . They tell me the cleanings are alot easier than doing the old GEs . I guess that's a relative statement - anything is easier than cleaning a GE . Besides , throw in a Riello and you'll be brushing it down every 10 years .
I don't think the LE comes with a coil , best to check their website .
The battle goes on . Just installed another steamer today which came out real nice . I hate it when that happens and the camera batteries go dead . How are things up north of here ?0 -
ok that makes a difference
Didn't know you needed a coil..How about the crown Tobago? Check the Crown site..think it might fit...0 -
Busyer than ever
i tell ya ron, i know what you mean , on of these days i'm going to put a plutonium reactor in my camera, and strap it to the truck so i won't forget it, well were up to 8 trucks now and i still can't keep up, i did a couple of 9 sec.80s w+m one water and one steammer, i got to go back and get some pictures, i aslo did my frist viesmenn that was fun,
that gold hanging on the wall was sooooo cool great job!!
remember you ever get the need to move to Gods country in new england there be a glow in the dark beaconmoble waiting for you LOL...happy holidays to you and you family...David0 -
If you don't mind steel
Laars Horizon and Columbia's Star Series are both rear flue with coil options. Newmac has a short unit that has a coil also.0 -
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
