Suburban GSW-20K (20,000 BTUH) Through The Wall Heater
Igor Gurevich
Member Posts: 1
We are looking at an old Suburban GSW-20K (20,000 BTUH)thru the wall heater. We are trying to locate parts for it - namely the Gas Valve and the Thermocouple. Did not have much luck searching the Internet - Does anyone know if and where the parts are available - Thank You Very Much.
If you give me the
information on the existing gas valve I can help you. Is it a 24 volt system or a hydraulic type space heating control?
If there are some numbers and type of gas valve information available I can cross reference you a part number. Then your local heating supply house should be able to hook you up with a part.
If you can also give some info on the type thermocouple that is in there now I can give you a replacement. There may be some numbers etched into the thermocouple.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
