Old Boiler Gas Retro-fit
Brian M.
Member Posts: 2
Hi
I have an old boiler that has a gas regulator, pilot (Baso), and a gas valve. I would like to be proactive for a change and replace these 3 things with a combination gas valve; however, I have no idea what gas valve I should use. I'm hoping that you can advise me. Here's the details of the boiler:
American Radiator and Standard Sanitary Corp . . . Boiler G25 DP . . . Series 4B J3 . . . Input 120000 . . . Output 96000
The pipes are 1/2 galvanized.
Thanks in advance and be sure that I will buy a brick.
If it ain't broke
don't fix it is my advice. Some old controls last longer and are less trouble than new ones.
If however you still insist you want to change it I need to know is it a 24 volt system?0 -
Missing info.
I thought I listed all the info. but how could I forget the voltage???? Yes, it's 24 volt - thanks.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
