Thermostat Wiring - Color Codes
hydronicsmike
Member Posts: 855
no one else have any feedback??
Mike
Mike
Is there a standard? - 2 Heat / 2 Cool / 2 Fan
Hello Guys,
Having been limited to just a number of different thermostats on the market, I was wondering if you may be able to help me understand something.
For thermostats with 2 Stages of Heat, 2 Stages of Cool and maybe even 2 Stages of Fan, what are the standard color codes for those.
I think I understand the single stage deals, but clarification is always better than thinking
Thanks for your help.
Mike0 -
I'll take a stab at it....
I'm gonna guess it may partially depend on your local,In these parts usually it's (now this is also dependant on how many wires are run) R-red W1-white W2-brown Y1-yellow Y2-blue G-green C-black.But I've seen many variations in my time....It's not so much the color of the wire as the matching the correct terminals.(Like on VVT or Lennox logic or Trol-o-Temp panels I would run Green and White out of the control transformers instead of Red and White just so I could reference that circuit for example)I will say this....
R(red)is usually hot,G(green)is usually fan & W(white)is usually heat,other than that it's really up two you unless the wireing diagram for the equipment or controls dictate otherwise...:-)0 -
Thanks Ranger. Muchly appreciated.
I am basically looking what the Industry uses as a standard. I wouldn't even try to believe for a minute that whats shown in a brochure is what is actually practical in the field. At least I don't know anyone of hand who would run looking for a cable that has a violet, purple or even pink wire in it
Hoping to get more (different or the same) feedback on this...
Mike0
- 428 Carbon Monoxide Awareness
- 114 Geothermal
