Pipe Insulation for One-Pipe Steam system - Homeowner
Whitney_2
Member Posts: 4
I am new to steam heat and am trying to learn as much as I can to solve some of the issues I am having. I noticed talk about insulating the pipes, but when I look at the hardware store, none of the insulation tubes are the correct diameter for my pipes. Where can I get the proper size of insulating tubing for the larger (approx 2 1/2 inch) pipes?
Thanks for your help.
Plumbing store
I went to my local Plumbing store the hardware stores don't carry the correct sizes. You can also order them online. www.statesupply.com
Hope this helps and happy steaming0 -
I used
A roll of fairly thin 3" wide fiberglass insulation that can be found at both Home Depot & Lowes. I think it is made by Frost King. 50 ft for $4 bucks. If you go around a few times. it seems to work. At least my basement as cooled down alot and i can grab hold the pipes with no problem where they used to be alomst red hot.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
