Pressuretrol question - Homeowner
Dot_2
Member Posts: 25
Should the pressuretrol be attached to the Low-water cutoff?
I have attached photos to show the two (2) boilers in two family house. Having looked through Dan's books (Got Steam and Lost art of Steam heat) I did not see where the pressuretrol should be attached to the boiler or I might just have missed it.
So my question is pressertrol1.jpg right or wrong?
Thank you in advance for any assistance that is provided.
Dot
Dot
Both are fine.
Just look like they're set a tad high on the pressure scale.
Should run between 1/2 a pound and 2 p.s.i. tops!
If either is a vapor system, 1/2 to 1 p.s.i.
Good grief,
where are these two, in a museum??? :-)
Call someone and replace them, you're fuel bills must be something else. Every time I think all of the dinsosurs have been buried, two show up in the same basement.0 -
Nope no museum
The one that I have added the new main vent and radiator vents along with some other changes appear to be working well. Getting 72% efficiency which according to Dan's book "got steam is on 8% off that of a new one.
But they do look like big monsters in the basment!
Museum pieces
These look like the same circa 1930 American Radiator Company boiler that I just sent to "the big boiler room in the sky" back in September. Originally a coal burner, was converted (I'm guessing) in the '50's to oil. I had the original pressuretrol and gauge at the top (not on the LWCO), which I'm sure never worked due to a clogged pigtail.
The chamber at the base of the unit finally gave up the ghost. A "wet pack" temporary repair lasted six years; kudos to my service guys! In the 13 years that I've been in this house, it's been cleaned and serviced every year, and every year was giving between 65% - 70% efficiency. However, it was still a fuel pig. So far this year, the new Columbia unit has only used 1/2 tank of oil (Reading, PA area). Granted, new Hoffman #75's and a few new #1A's are also helping the cause.
They don't make 'em like they used to...
Mike0 -
museum Piece
Correct they are both Arco made by the American Radiator Company & Ideal converted to Oil in 1954. Only know that because the certificate is still attached to the wall near the boiler.
That's combustion efficiency
Dot, your thermal efficiency is about 30%, been there, seen it thousands of times, FACT!0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
