dis-colored domestic hot water
James B.
James B. Member Posts: 1
Anyone have a good sound explanation why domestic hot water tends to dis-color when it has not been used for a while. I have a four zone domestic hot water system with returns using Ajax semi-instantaneous hot water boilers. When the hot water has not been used for a while it comes out with a brownish tint. The building is located in New york city. I do not believe the supply is the cause and besides the cold water is not effected. The building is brand new, brass and copper no black pipe issuses. Why would the heated water tend to dis-color? I appreciate your thoughts.
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    Dis...!
    Does the water smell like rotten eggs? If so, could be an anode going bad in the water heater...Robert O'Connor/NJ
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,749
    If water...
    sits long enough, even in copper, it'll turn brown. Do you have a way to move that water occasionally? It sounds potentially unhealthy.
    Yours, Larry .....ps. What are the Ajax boilers made of?
