steam to hot water
Tom_52
Member Posts: 1
i have a weil mcclain steam boiler, i am in the process of installing radiant heating in my home.could any body tell me what i would need and what i would need to do to convert my steam boiler to hot water thank you, Tom
Tom..
The Weil-McLain you have, is it an EG boiler? If so you could buy the water trim available for it. EG boilers go both ways (meaning steam or hot water). You will have to undress the lady and plug some of thee ports and unplug others. I'd give it a real good cleaning too. You won't get the efficiency of a true forced water boiler but you probably wouldn't be asking if money wasn't a issue...Robert O'Connor/NJ0 -
We have the products to clean and treat your system
after it has been converted to hot water. The cleaning and treatment will let the system operate at as good an efficiency as you can get.
Call me at 800-543-5975 or check out our products on our web
site under Hydronic Products. www.rhomarwater.com
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
