boiler water line
John Shea
Member Posts: 247
I've been doing some troubleshooting on a two-pipe, gravity return vapor system.
Last week, I corrected a venting problem, and a problem with the pitch on a wet return. The system ran better (pretty good) all weekend, however, when I checked on it this morning, the Pressuretrol kicked off the burner (after about 5 min.), then the waterline almost disappeared (if not did disappear) for a moment.
The LWCO started feeding water, then after a minute, the pressure dropped and the burners kicked back on.
Now, just before that, I did drain the bottom off about 5 gallons, however, this being a 1,500,000 btu boiler (not sure what water capacity) I would not think that this would cause the SUDDEN BWL drop.
Any ideas are very welcomed.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
