Mr Glenn Stanto
Wild Bill
Wild Bill Member Posts: 111
Good Day Glenn,
What do you suggest using on the push nipples for 9A cast iron baseboard to facilitate drawing the sections together??
Thank you,
Bill Hobbie
  • Used to recommend
    using an oil-based nipple lube. This was the same lubricant that was shipped out with the Knock-down boiler assembly kits. We are now using a lubricant sealer from Loc-tite that is white in color and remains pliable for many years to come. I will check on this tommorrow afternoon as soon as I finish up with the group I am training down here in Southern Jersey.
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
    www.burnham.com
  • tim smith
    tim smith Member Posts: 2,841
    baseray
    The new nipple lube is much better than the old stuff you always had to mix and mix to get it to proper state. Make sure to clean nipple ports with pipe sandpaper before putting nipples in and lube both nip and port.
  • The new lubricant
    that we use is LocTite #592. It is white in color and remains pliable. Hope this helps.
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
    www.burnham.com
