Where should pressuretrol be installed?
Dot_2
Member Posts: 25
Good day all,
I have a quick question about the pressuretrol proper location on the Boiler. Since I own a duplex there are two (2) boilers in the building, one of which I have made changes in accordance with suggestion for this board and Dan's book.
But I did not see where the pressuretrol such as with the pressure gauge pigtail right / wrong photo in the "Got Steam" book.
One of the boilers has the pressuretrol attached to the low water cut off is this correct? The other boiler has it on a Tee which holds the pressuretrol and pressure gauge.
Any assistance would be greatly appreciated.
Dot
Dot
They are both
in acceptable locations.0 -
Thank you
Was worried that it was in correct now I feel better.
Again thanks
Dot0 -
Firedragon is
of course correct!
Sorry for the double post I forgot the pictures the first time
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
