Horizontal H2O flow indicator?
Dave_16
Member Posts: 51
I'm wondering if anybody knows of a flow meter designed to install into a horizontal (staple-up radiant) piping job. The supply & return manifolds (copper and plastic) are up close to floor joists, so I don't have much rooom for the usual vertical flow meters; I understand the prinicple of operation requires vertical flow against gravity, but I'm hoping there's a compact type somewhere for tight spots like I have. System is currently not balanced.
Gracias,
Dave
Gracias,
Dave
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
