Taco 007 Pump ???
CHad @kinnard Heating
Member Posts: 8
Can this pump be mounted vertical, meaning the pump portion is facing up. Someone is telling me that it can't.
Thanks in advance
Thanks in advance
The installation instructions....
....specify that the pump shaft (cartridge, in this case) should be in the horizontal position. Mounting it as you are suggesting could end up in premature pump failure.
Starch0 -
Thank you sir!0 -
Pump Orientation
The flow direction can be vertical or horizontal. Taco specifies horizontal mounting in the instruction sheet, and it's the motor orientation not the casing of the pump they are referring too. For your reference I attached the instruction sheet.Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
