optimum settings
JM_5
Member Posts: 17
what would be the optimum settings on my peerless oil burner? what should the high limit and circulator be set at? Thanx
the reason no one has replied is they have no idea.....
What Peerless boiler you are refering to,nor do they have any idea the type of application the peerless is being used For,or the type of emmitters,or the control stradgey or the type of fuel it uses ...for starters.. lets say it was an oil fired boiler with a triac ustat well,maybe 145-175 might be good,then again there are alot of minor technicalities....your question is alot like mine the other day when i went to pay my bill at the telephone company hello says i "ok.So how much is my bill this month?"Your supposed to"Know"...if you were any Goodt your job Youd have had your crystal ball clean and shining right there in front of you and be able to tell me Immediately
........ 0
