on a munchkin boiler
gerry gill
gerry gill Member Posts: 3,083
where do you take the combustion readings from? do you drill and tap/plug a hole in the vent?
gwgillplumbingandheating.com
  • Jeffrey Campbell
    Jeffrey Campbell Member Posts: 51
    Good Question
    I have been trying to find a better way. So far I have just drilled into the vent stack and used foil tape to cover but now I have been trying to come up with a cleaner and more professional solution. What about a 1/4" nipple and cap? I just need to find out if the flue condensation will eat the nipple? What do you think
    Jeffrey
  • Murph'_5
    Murph'_5 Member Posts: 349
    drill and tap....
    to a 3/8 bolt or whatever size your analyzer needs!! could put sum silly-con on the threads.
    Murph'
  • Guy_5
    Guy_5 Member Posts: 159
    tapping
    Tap the hole with a pipe tap (3/8, 1/4) and use a PVC plug.
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    Here's how I check all pvc vented appliances...
    Drill a 5/16" hole. Tap it with a 1/8" NPT tap, don't send the tap all the way in or the plug will be loose because of nylon to plastic. Install 1/8" NPT nylon plug with a little teflon tape, and your good to go.
    Source for 1/8" NPT nylon pipe plugs:
    http://www.mcmaster.com/nav/enter.asp?pagenum=163
    By the way, the useof a metal/steel bolt is a bad idea, as the metal will corode and the bolt could snap off and drop down the pipe.
    Also, if you need plugs for regular flue pipe, drill a 5/16" hole, then use part # 9563K83 - 5/16" nickel plated 5/16" hole plug near the bottom of this page:
    http://www.mcmaster.com/asp/enter.asp?pagenum=3481
  • munchkin-man
    munchkin-man Member Posts: 247
    A 7/16\" hole will provide for a 1/4\" NPT tap then a plastic plug
  • LES WEGENER
    LES WEGENER Member Posts: 7
    vent tapping
    I TAKE A UNIBIT AND DRILL A TAPERED HOLE IN THE PVC VENTING AND WHEN I'M THROUGH TEST I PUT A RUBBER 3/8" RUBBER STOPPER IN THE HOLE
  • gerry gill
    thanks all
    for the info, appreciate it.
