how do I put the picture inthe text rather than as an attachment
Mark Woll_2
Member Posts: 67
I know how to add an attachment, but how do I get it actually inside the text box itself? so nobody has to open an attachment. Thanks
After you pick your attachments... there is a spot to pick which one shows in the text page. The rest will be attached as links.
Good Luck0 -
If you want the picture INSIDE your text,
there is no other way to do it but to host the picture elsewhere and use a image HTML tag to call for it.
The invision forums allow you to attach an image and show up to one of them by enabling the check box at the bottom. However, such images will always follow your text, rather than be part of it.0
