Vitodens Operation
Mike T., Swampeast MO
Member Posts: 6,928
Have my program just about complete. Attached .pdf is MUCH more detailed than the previous. I also found a scaling problem when graphing and the graphs weren't positioned properly with regard to temperature. They're dead-on now.
Sorry it has to be in .pdf but I run my monitor at 1600x1200 resolution and use every bit of the screen for this program. Probably the best way to view is to print out on a color printer. Comes out fine on mine and even the tiny text is quite legible.
Notes on my interpretation will follow tomorrow.
Neat...
... as I'm on my second gin & tonic, while waiting for the wife at a local bar, it'll take me some time to comprehend. Looks great though!0 -
You're like a little kid with a new...
Etch-A-Sketch
hot rod
You Got It!
But no matter how hard I tried, I just couldn't get a decent CURVE out of my Etch-A-Sketch...
Interpretations
nm0 -
Delta-T
My "perfect" reset curve calculated before installation said I should have 36° delta-t regardless of outside temp.
So far I haven't measured anything even close to 36°.
The modulation period was forced by raising numerous TRVs from 10° setback. I doubt that mean radiant temperature had a chance to stabilize before I ended the test.
Stay tuned for colder weather because I'm not going to change my reset curve until I see what happens when hour-by-hour loss exceeds 24 mbh.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
