0-16oz or 0-4psi Vaporstat?
Brian in Indy
Member Posts: 15
I've got Pressuretrols, and like most have experienced here, with setting at 0.5 and differential at 1 the boiler runs until about 3psig and cuts back on around 1. I'm confused by the literature on the vaporstat L408A - if I go with the 0-16 o.s.i. is there a chance that I won't be able to run the system at high enough pressure, conversely, if I go with the
I am in the process of replacing all traps (or replace cages) and the system has been mostly insulated (all mains). Currently at the 2-3psig there is NO problem getting all the radiators hot.
THANKS for your input-
Brian
Brian
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
