more hydronic speciality valves
hr
Member Posts: 6,106
www.ravenproducts.us had some unique valves and tools. I like the small 1/8" air vent iso valve. It had a deep FIP side to allow the vent to screw in. Handy!
Also the expansion tank iso valve with a drain port was clever.
Iso valves similar to Webstone but not as deep as a line.
I've had the B&G iso flanges on order for over a month. Now I hear from my rep that they won't leave China till December. Wish they would get inventory in place before they take out those full page glossy ads in all the mags!
I think this off shoring may turn out to be a bumpy ride for some manufactures. Nothing like a slow boat from China to piss off the contractors :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
I was looking for one of those...
expansion tank valves just a couple of weeks ago, and couldn't find one. Thanks for the heads up HR.
By the way, you might want to contact the Chicago B&G rep. Bournquist INC. to confirm the availability of those isolation flanges. Seems like a few suppliers have them here in Chi town, although haven't tried to actuallyordera set. Every supply house I go into that has them on display says they are in stock.
www.bornquist.com0 -
Another exp iso valve
Jomar, and probably others, offer mip X fip ball valves. This is a nice valve with all the listings. I always remove the handle when I use them for expansion iso.
hot rod
I've seen the FPT X MPT valves before,
but couldn't find one with the bleeder on the tank size before. That bleeder would make things much easier on maintenance calls to check the air pressure.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
