hi co reading
ed wallace
Member Posts: 1,612
I replaced a 75 gallon gas waterheater today after turning it on i noticed back pressuere at the draft hood due to partailly plugged chimney after clearing chimney blockage the co readings went up to 200ppm when the boiler runs no problems vent for waterheater is lower then the boiler vent 1 side of the chimney is on an outside wall any suggestions other then rerouting vent so its higher then the boiler vent
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=256&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Where are reading this at? Also what about stack temperature, draft and 02 readings? You may have an air curtain effect going on.
Brian0 -
In Mass it's code to vent your water heater before your boiler.. almost sounds like maybe the chimney liner is shot, or oversized, and when only the water heater is firing the stack can't get up to temp and causes down drafts... does the chimney ever condense?0 -
hi co
will be going back tomorrow to inspect the chmney during the day was hard to see if it was lined old waterheater had worked for 10 yrs no problem
huh?
It's mass code to vent below the boiler vent going into a chimney?0 -
Agree with Brian
What were your other readings AND what was the draft AFTER you cleared the blockage?
Where in the flue were you testing?
When you go back, check those things and let us know. We can fix this together!
AND MOST IMPORTANT.................THANKS FOR TESTING!!!!!!!!!
All the best my friend!
Mark H
Check the input rate too
it may be a bit high and only producing CO under certain draft conditions.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
high CO readings
did a test using a testo combustion effiency tester 1 st test with boiler off the readings are stack temp 506 degrees 02 6.5 eff 80.4 CO2 8.1 draft 0.00 test 2 with boiler running stack temp 520.7 02 7.0 eff 79.0 CO2 7.8 0.02 chimney is not blocked
high CO
anyone have any other ideas
Is this a gas boiler Ed?
Mark H
high CO readings
mark its a bradford white 75 gallon gas water heater
Check your e-mail Ed. (nm)
Mark H
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
