high hats
bovide_4
Member Posts: 161
I am doing my bathroom over and trying to find recessed lights for the ceiling that can be insulated over. The problem is:
1) a 20 degree sloped, cathedral ceiling
2)should be rated for wet locations
I found an eyeball fixture for a shower-however, it is low voltage, which gets too hot to be able to insulate. Can I make a 3" enclosure around the fixture with wire mesh to keep the insulation away and still insulate around it?
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
