stuffing box or mechanical seal on condensate pumps
Doug Wagoner
Member Posts: 78
condensate return pumps. I have a 6 gph low pressure, steam boiler with duel condensate pumps that need replacing. The debate is whether to replace with mechanical seals or continue with the stuffing box for the shaft seal. What would you do?
what do you prefer: stuffing box or mechanical seal on
condensate return pumps. I have a 6 gph low pressure, steam boiler with duel condensate pumps that need replacing. The debate is whether to replace with mechanical seals or continue with the stuffing box for the shaft seal. What would you do?0 -
packing--0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
