Making water?
Scott Brink_2
Member Posts: 21
I don't know if this is uncommon, but over the summer when the boiler wasn't firing up very much, the water level in the system rose. Water is not automaticly added to the system. Any ideas where that extra water is coming from?
It is particularly perplexing, because over the winter it seems as though I have to add water from time to time.
Any thoughts or ideas?
Any thoughts on the water issue?0 -
water or steam.....
Is/was there a tankless coil?
Steam with a tankless coil
It is a one pipe steam system with a tankless coil.0 -
that would be.....
your problem. You probably have a pinhole in the coil and it is filling the boiler. It should be replaced. kpc
either the tankless coil has a hole, or the manual fill valve is passing water.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
