Beckett HeatManager............
Firedragon_4
Member Posts: 1,434
but does that include labor???
Either way, if it's less than 10% of his fuel bill, go for it. The ROI will be in one year. It's essentially a form of indoor reset or adaptive intelligence.
Read this:
http://www.beckettcorp.com/heatmanager/
Read this:
Beckett HeatManager..............
A friend of mine has said that Standard Oil has offered to install a Beckett HeatManager for free on his heating system. Has anybody had any experience with the Beckett HeatManager? Is it any good? What do you think?
JR
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"I am the walking Deadman
Hydronics Designer
Hydronics is the most comfortable and energy efficient HVAC system.0 -
The HeatManager works great,but there is no free lunch!There is a lock-in period at the least
It looks like the more oversized the boiler is the better it works. From it's operation, it seems like it is more of an adaptive differential control rather than an adaptive reset control so it should help a lot with short cycling.
Ron0 -
I've installed one.
Only saw it run a few cycles during purging and efficiency test. Never saw it enter "economizing" mode. It seems like an easy to install alternative to outdoor reset. It senses the demand for heat by the rate at which the supply temp drops and varies the high limit differential accordingly. An optional sensor allows it to override if there is a call for hot water, either tankless or indirect.
Tom M.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
