Master Vent Sizing
superMARKet
Member Posts: 87
I'm looking to even things out a bit (and spend less money on oil) in my one-pipe system by adding top-of-riser main venting. This is an idea I've been kicking around for a few years but thought it was kooky 'til I read Lost Art and some postings around here.
Right now, I have no working main venting. Can anyone suggest main vent sizes?
I have two mains. The rear one is dry return, angled up and away from the boiler for about 5 feet, and then into a 30-foot riser supplying half of my radiators. The main and riser are both 1+1/2" pipe.
The other main is a wet return, 2". It's 40 feet long and runs to the front of the building. Halfway through, it feeds one 2" intermediate riser which is 15 feet high. That riser then splits into two 2" risers which continue for another 25 feet. There's no radiation on these middle risers other than the pipes themselves, just a Hoffman 45 at the top of each.
At the end of the long main, there's a 35-foot 1+1/2" riser feeding the other half of my radiators. The only main vent in the system is at the end of the long main, before it drops into the wet return. The main vent doesn't work.
It takes 15 minutes from cold start (170o aquastat) to get steam to the tops of the front and rear risers. It takes 30 minutes(!) from cold start to get steam to the tops of the middle risers (with no radiators.) How much can I expect these numbers to drop with top-of-riser venting?
Thanks,
Mark
Thanks,
Mark
> Right now, I have
> vent sizes?
> The other main is
> each.
> work.
> venting?
> Thanks, Mark
Mark,
venting
Mark,
I am not a pro, just a homeowner with an interest in steam, but I do know that you should replace that main vent that is not working before you do anything else. Getting all that air out of the 2" main will only speed things up. I would imagine that a Gorton #2 would be a good main vent to use here.
Next, make sure your pressurtrol is set to under 1 lb. Then, insulate all those mains, and finally, make sure that the vents on your radiators are working. The key to getting the steam to your rads fast is making sure that the air has a place to go easily and quickly.
Good luck,
Thad
The charts you need
are in the workbook that comes with the "Dead Men's Steam School" video. This would be a good purchase for you, since Dan goes thru the procedure for sizing vents in the video. And you'll really enjoy seeing him doing his thing- I always do!
Order yours on the Books and More page of this site.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
I'd get a kick out of seeing Dan in action in person, too - looks like I'd love the Lost Art seminar. D'ya get much of my type at those events? (That would be the hands-on building manager-ish superintendint-ish type.)0 -
Yes, we do-
the more, the merrier!
Consulting0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
