RIDGID PROPRESS TOOL
BILL FOSTER
Member Posts: 1
I am thininking of buying a Rigid ProPress tool. Does anyone know of problems with it. Any problems with the EPDM seals? Thanks
used it a LOT
3"ipe, with water pourin'outta it ... heating ... done a whole school .... downfalls ...
1) price of tool
2) price of fittings
3) price of fittings
4) price of fittings
50 price of .....
!0 -
Is your labor free?
Isn't the customer paying fo rhte material AND the labor?
The savings are there, if you value your labor.
ME
Biggest problem
is when you forget to crimp a fitting and it holds 65 lbs of water untill 8:30 pm and then lets go and floods a boiler room.
Don't ask how I know that.
Other wise we love the tool.
Scott
Awesome!
One of the best investments I've made.Only drawback has been fitting availability,but thats changing as more supply houses are starting to stock them.
I learned at ISH that they have changed the fittings slightly so a leak will show up on a air or water test.They will be making them so they leak slightly unpressed.0 -
pro press
I to just began pricing these out going to buy one this week any feed back ct400 vs. battery 320e?0 -
The Press
We have the corded model which has been great though a bit cumbersome. You don't want to hold it up in the air too long!
Haven't yet had the experience of forgetting to crimp one, but I did neglect to lock down a Victualic "FIT" fitting on a fire service once. Held pressure to about 85 lbs before it let loose and painted the walls with the black "ink" water that lurks in sprinkler systems.
I TRIPLE check all mechanical joints REAL carefule since then!There was an error rendering this rich post.
The Press
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
