What's causing high pressure in HW Boiler
Kyle Kubs
Kyle Kubs Member Posts: 12
Ok, I need to defer to the real pro's here... Inspected a house last month. Older oil fired weil HW boiler. Pressure cold was around 20psi. A bit high, especially for a two story on a slab, 12 would have been fine, but ok... Crank er up and the pressure starts climbing right away. I'm watching and it hits 30... 31...32... Still no discharge from the PRV. I shut it down and check the expansion tank - the first few inches near the tapping is good and hot but the rest is cold so I assume the bladder isn't ruptured and the tank isn't water logged. So my question is, barring a bad expansion tank, what else would cause a high pressure condition like that. I did turn off the fill valve to isolate a pressure reducer that was being somehow affected by the heat even though that is unlikely. Of course I recommended the client bring in a hydronics pro for an evaluation but they never get back to me to let me know what it was...
  • Weezbo
    Weezbo Member Posts: 6,232
    You Told us the water pressure is 20 psi.
    Theres the answer.reduce the start up pressure ,reduce the temperature, not everyone uses a 30 psi pop off...the domestic coil has a leak that gets particulairily bad with heat,the gage is lying to you,the high limit is fried and the gage is lying there by pumping X psi cold water to<Temps than normal.. theres a few ideas on what may be happening.
  • tim smith
    tim smith Member Posts: 2,835
    rising pressure
    It would have to be either a blocked line to expansion tank or a bad or depressurized expansion tank. Also check setting on prv, if 30 and gauge is accurate, replace it. Also agree that the pressure only needs to be around 14-15psi. Good luck, PS it could be what Weezbo say's also but I would be surprised.
