Booster pump flanges
Robert O'Connor_5
Member Posts: 25
I replaced one of my 6 B&G 100 pumps with a Taco 007.... all went really well and the price was right too. I noticed that some of the other B&G pumps I have are mounted in a way that I may have to rotate the flanges 45 degrees or so to make clearance for a Taco 007 to fit. Whats the best way to do this to the flanges.... perhaps a pipe wrench?? Hopefullly it wont leak at the flange threads then.
flange rotaition
pipe wrenchs ,(2), will work, or drop a pair of spent bolts thru the flange holes and you've got a spot for a lever. happy trails..0 -
perhaps 2 pipe wrenchs---and a boiler guys phone number --when it doesnt come off or you break the pipe--------- hold back w/1 wrench stick the oldbolts in the holes put a bar in and turn--make sure you are tightening when you turn--0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
