oil line
Derek_2
Member Posts: 1
I just replaced the oil fired boiler in my house. I have the New one in place and connected, but I can't seem to get the heating oil to flow from the tank. It's a two line system that worked fine before I removed the old boiler. Does anyone have any thoughts????
My first suggestion would be to call a pro in to check it over and perform a combustion test to make sure its safe. The second thing would be is the bypass plug installed? If you don't know what this is call a pro and keep your family safe this winter. Hope that helps. good luck!
Paul0 -
secret plumber ninjitsu...
Wont work at all with out that by pass plug. not with a two pipe system...0 -
Is it possible...
that you inadvertently switched the supply and the return line. Why not just make it a one pipe system with a Tiger loop air eliminator. Moves less oil and no return line leak worries.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
